Skip to main content
< Back to Search Results
3-phase AC-DC Boost Power Factor Correction with Embedded Code Gen & HIL Simulation
The design and simulation of a 3-phase boost PFC with verification using a Typhoon HIL simulation is the topic of this webinar. The simulation covers how to close the loop using dq control and then set up the simulation to generate code for a C2000 processor from Texas Instruments. We then verify the code with a real-time HIL simulation using a Typhoon HIL 600.
Some specific topics covered:
- Closing the current control and voltage control loops for a 3-phase PFC with dq control
- Setting up the simulation to generate code for a C2000 target
- Compiling the code and loading it to the target
- Setting up and verifying the simulation with a Typhoon HIL system
Software and Hardware used:
- PSIM Professional
- Digital Control Module
- SimCoder with F2833x Target
- Typhoon-HIL 600 real-time simulator
- F28335 ControCard from Texas Instruments
- SmartCtrl
