A New and Revolutionary Way to Collect Energy from Wind
David Yáñez presents at the UK ATC 2019. Vortex Bladeless is a Spanish start-up that is developing a new wind energy technology. Its key characteristic is the minimization of mechanical elements that can be worn by friction. In the first stage, its application area seems to be distributed energy. For its development, CFD tools are being of vital importance. Both the fluid-structure interaction and the behavior of the magnetic fields in the alternator are being studied mainly with this type of tool. The results obtained are being contrasted with experimental results obtained both in wind tunnel and in real application environments.
A general vision of the technology, the strategies used for the integration of the different physical phenomena involved and the path traveled for its development will be exposed.
