AI Agents of Change: Automate. Accelerate. Simulate. Featuring Lucid Motors
Instead of spending hours on setup, data prep, and manual reporting, AI agents can now handle these repetitive steps, allowing engineers to run more iterations, explore more design options, and deliver results faster.
You’ll see how agentic AI delivers value across the workflow:
Intelligent CAE Automation: Automatically retrieve CAD models, apply material properties, and set up boundary conditions, cutting simulation setup from hours to minutes.
Seamless Workflow Integration: Connect AI agents directly to your existing CAE tools to run analyses, generate standardized reports, and reduce manual data handling.
Customization for Real Projects: Learn from Lucid Motors’ seat frame design workflow, where AI agents used metadata tags to enforce design standards and accelerate iteration cycles.
Whether you’re an engineer looking to eliminate repetitive tasks, or a leader aiming to shorten design cycles and reduce costs, this session will show practical ways to apply AI agents in your development process today.
