Andron Handling needed to assess the strength of the welded fabrication and vertical clamping arms for both lifting and clamping loads. In previous analysis of this type in Altair SimSolid™, they would have removed the wheels from the model and applied reaction forces at the bottom of each of the clamp arms. In this case, Andron used a different approach that would not have been possible with previous FEA toolsets.
