Skip to main content
< Back to Search Results
Antenna Coupling using an Equivalent Source and Ideal Receiving Antenna
Calculate the coupling between two horn antennas separated by 60 wavelengths. A metallic plate between the horn antennas blocks the line-of-sight coupling. Replace the horn antennas with a far field equivalent source and receiving antenna.
