Battery Part 2: Rapid Battery Layout Optimization using 0D / 1D in a Systems Environment
Andrew Dyer, Senior Tech Specialist at Altair in the US, Gabriele Piombo, EngD Partner with Altair at the University of Warwick, and finally Prof. James Marco, Professor of Systems Modelling and Simulation at the University of Warwick, present - Rapid Battery Layout Optimization using 0D / 1D in a Systems Environment.
Together they will discuss the use of a 1D Systems approach to simulate a battery module. This includes the cell, cooling plate & busbar and is subjected to a typical extreme duty cycle. A typical event is simulated where the maximum allowable temperature is exceeded which triggers an increase in the cooling flow rate. This system is then optimised.
