Skip to main content
Altair Compose®
Math, Programming, Data Analysis, and Visualization
Analyzing data, developing algorithms, or creating models - Altair Compose is designed to bring your ideas forward.
Altair Compose is an environment for doing math calculations, manipulating, and visualizing data, programming, and debugging scripts useful for repeated computations and process automation. Altair Compose allows users to perform a wide variety of math operations including linear algebra and matrix manipulations, statistics, differential equations, signal processing, control systems, polynomial fitting, and optimization.
The broad set of native CAE and test result readers accelerates system understanding and works with Altair Activate® to support model-based development, for multi-domain and system of systems simulations. Altair Embed® completes the model-based design portfolio with automated code generation, allowing for the testing and verification of embedded systems.
Why Altair Compose?
Better Engineering Decisions
Perform useful engineering calculations based on first principles, either one-time or repeatedly (when archivable as reusable scripts), and with pre-or-postprocess data. Then easily plot results and make informed decisions.
Affordably All-in-One
All capabilities are available in a single, multi-functional tool with a user-friendly integrated development environment (IDE), with no additional toolboxes required.
Easily Accessible
Can be used on its own or with other Altair products, which are accessible through Altair’s innovative unit-based licensing system.
NOW AVAILABLE
Get started with the Altair Compose® Personal Edition
Transform your data into valuable insights with the Altair Compose Personal Edition – the ultimate solution available to everyone, including for both commercial and business applications.
Download Now
Key Features
Numerical Computing
Includes hundreds of powerful math operations and built-in functions for calculations ranging from ultra simple to super complex.
Rapid Algorithm Development
Users can explore multiple approaches and find solutions faster than with spreadsheets or traditional programming languages such as C/C++.
Multi-language Math Environment
Based on the Open Matrix Language (OML) and is also compatible with Octave and Python.
Process Automation and Scripting
Especially handy when doing often-repeated calculations or streamlining common processes. Also includes a useful debugging ability.
Plotting and Visualization
Useful 2D and 3D plots provide richer insight from your calculations and data.
Built-in CAE Data Readers
Easily import, visualize, and manipulate data for physical testing and CAE like FEA, CFD, electromagnetics, multibody, and more.
Key Capabilities
Signal Processing
CAE Test Data
Curve Fitting
System Dynamics
Read CAE Data Natively
Coupling with Python
HyperWorks Automation Tool
Digital Data Compression
Custom Library Creation
Flutter Data Analysis
Fatigue Damage Evaluation
Auto-generating Input for Feko
