Skip to main content
< Back to Search Results
Evaluate the Structural Strength of Bulk Material Handling Equipment using EDEM-OptiStruct (Explicit FEA) 2-way coupling
Prasad Avilala, Sr. Technical Specialist - EDEM at Altair presents at the 2024 ATCx DEM.
In this talk, the EDEM-OptiStruct solution is demonstrated for bulk material handling applications such as dump trucks, surface miners, tunnel drill bits, and post-hole diggers. Bulk material handling is crucial in industries such as mining, mineral processing, agriculture, pharmaceutical, automotive, and food processing. Altair EDEM simulates and analyses the behavior and forces of bulk materials in these applications. Coupled EDEM with OptiStruct allows structures and equipment to be optimized for strength, durability and stiffness based on the material interaction forces.
