From MBD to FSI Complete Firearm Development
These days, in IWI, complete multi physics simulation is an integrated tool in the development of any new product. The motivation is to completely simulate one or two firing cycles as close to reality. First step is the Multi Body Dynamics simulation to check all mechanism are synchronized and work properly. Second is the explicit simulations - calibrating the mechanical properties of the pistol, in that the springs, contacts, materials and gun powder properties based on one firing cycle. The following is to calibrate the Non Rigid Boundary conditions (NRBC’s). This calibration of boundary conditions which are not completely fixed is crucial to understanding the actual strains and stresses on the parts. One of the approaches was to use known data of the stiffness of arm and wrist, implementing this data into a HyperStudy model to compare and calibrate the results based on a slow motion capturing of a real firing. The results are promising, with high accuracy of the behavior compared to a real capturing of the shooting, up to the point of slider getting to the end of its move – where most of the kinetic energy transform into loads on the frame. The following steps will be to calibrate, using the same method, the return of the slider to it’s original position and perform more than one firing cycle.
Presentation by Konstantin Arhiptsov & by Eitan Maler, Simulation Dept. IWI Israel Weapon Industries (IWI) at the ATCx in Israel, Netanya on October 30, 2019.
