Getting Started with PSIM - Building a Buck Converter
Join us for a one-hour journey through PSIM and learn how to build a buck converter from open-loop to close-loop.
Since Altair acquired Powersim in March 2022, many new users might ask themselves: "How do I get started with PSIM and what can it even do for me?"
Are you one of them?
Or are you already an experienced user and just want to refresh your skills and see if there are any new tips and tricks?
Either way, this webinar is right for you. Join us for a one-hour journey through the PSIM software and learn how to build a buck converter from open-loop to close-loop.
We will also give tips on how to work more efficiently with PSIM by using some shortcuts.
Main learning concepts that we will touch on:
- Library elements
- Hotkey setup
- Simulation setup
- Timestep
- Total time
- Waveform analysis
- Adding waveforms
- Saving setups
- Adding screens
- Measurements
- Changing y-axis
- Timing
- Dual/triple etc.
- Introduction to AC sweep
- Setup
- Two-loop control
- Open-loop
- Loop gain
- Parameter file use
- Variable definitions
- Sub-circuits
- Intro analysis tools
- Monte Carlo, Fault, Sensitivity
- Intro to Scripting
- Intro to other switch modes
- Thermal
