Skip to main content
< Back to Search Results
Global Stress Analysis of a Winch Grillage
A structural linear stress analysis of a loaded grillage using a range of connections and contact conditions to verify the structural integrity under multiple load cases. The grillage provides structural support for a 75 Tonne WLL drum winch and two overboard sheaves plus ancillary equipment to be used in an offshore lifting application. The analysis is performed using a winch line tension load of 33Te and incorporates the reaction forces, generated by the winch and overboard sheaves, transmitted to the grillage via bolted connections.
Presented at Altair's 2024 Simulate at the Speed of Design by Sonny Cowing, Graduate Mechanical Engineer at ACE Winches.
