Skip to main content
< Back to Search Results
InDepth FastenerPro Brochure
Download PDF
Validating fasteners is critical to ensuring the structural integrity and performance of products across industries. However, traditional methods - such as manual calculations or basic calculators - can be time-consuming, especially for larger and more complex systems.
Streamline your fastener validation process with InDepth FastenerPro, an advanced, versatile, and intuitive software solution for evaluating and optimizing the Factor of Safety (FoS) for a wide range of fasteners – such as bolts, rivets, pins, spot welds, etc.
The software efficiently scans direct output files from leading Finite Element solvers to extract axial force, shear forces, and bending moments of each fastener, enabling precise FoS computations for tension, shear, slip, combined tension/slip, and combined tension/shear - and for both static and dynamic loading scenarios.
