Skip to main content
< Back to Search Results
NovaFlow&Solid Tip: Dual Mesh Function
Download PDF
The advantage of using dual-mesh is that the detail can be filled with a slightly smaller mesh solution and then solidify with a higher solution, to ensure as high accuracy as possible using minimum time. Learn how to apply it with this document.
