Optical Modeling of Automotive LiDAR Systems
The use of LiDAR systems is becoming more popular in automotive applications. Optical analysis software such as TracePro allows engineers and designers to model these systems in a virtual environment and make wise choices before producing physical prototypes. Modeling these systems can be challenging in terms of setting up the source, choosing the appropriate properties, and working with small number of rays that return to the target. In this webinar we will look at modeling LiDAR systems in TracePro including setting up the model, defining the beam, and analyzing the results. We will also look at tools to improve the sampling efficiency of the model to get better results without the need for raytracing very large numbers of rays.
