Skip to main content
< Back to Search Results
Shiva Tool Tech Achieves 80% Time Reduction with Altair Inspire Cast - From Die Design to Defect-Free Castings
Shiva Tool Tech, an automotive manufacturing leader based in Pune, India, specializes in designing and producing gravity, low-pressure, and high-pressure die-casting dies. With over 25 years of expertise, the company provides end-to-end support, from process design to production, using advanced manufacturing techniques like CNC machining, EDM, and polishing. Their commitment to achieving defect-free designs involves rigorous physical iterations, where initial die designs are tested, inspected, and modified based on feedback. However, the limitations of outsourcing simulations, including high costs and long turnaround times, prompted Shiva Tool Tech to adopt Altair Inspire Cast.
Incorporating Inspire Cast into their workflow, Shiva Tool Tech significantly reduced the time and iterations needed to produce defect-free casting dies. This approach saved 80% of the time compared to traditional physical trials. The integration of Inspire Cast not only improved design accuracy and visualization but also enhanced operational efficiency, reinforcing Shiva Tool Tech’s position as an innovative and reliable partner in the die-casting industry.
