Skip to main content
< Back to Search Results
SimLab Hex Meshing using Extrude Functions – Y bracket
Mesh a geometry with hex elements. Generate an axi-symmetric mesh around cylinders and adjust the number of layers. Adjust the alignment of common faces and merge bodies with coincident faces.
