Skip to main content
< Back to Search Results
SimLab Tutorials - Modal Frequency Response Analysis of a Crank Shaft
Create a modal frenquency response analysis in the solution browser; define an excitation load based on applied loads; create a table with modal damping values; define the solution settings and output requests; compute solution and review results; plot and X Y graph for the displacements versus frequency
