Sound and Simulation: Designing a Smart Speaker
-png.png?sfvrsn=e1f7f1d3_0)
Speaker design and analysis, especially for a more complex product, system, or component, often requires building multiple simulation models. The loudspeaker development process involves multi-physics and multiple sources in parallel, to multiple simulation runs for prototyping, testing, and validation. This results in separate models for nonlinear analysis of strength, thermal analysis and stiffness, noise, vibration, and acoustics. Even though each model isn’t always built from scratch, typically the use of different solvers for each attribute will require that models need to be converted from one solver format to another. This practice is not only time consuming but frequently error prone resulting in an inefficient use of engineering time.
