Using the F28379D for Complex PWM Gating Signal Generation
How to use the X-Bar, PWM trip settings, ePWM, trip zones, etc.
The F28379D is capable of generating very complex PWM gating signals. Trying to make sense of it all can require extreme mental gymnastics. PSIM's code generation tools will help simplify this process so that you can easily simulate and move to the hardware stage with confidence.
This webinar shows how to:
Use PWM waveforms to trigger other PWM waveforms with different logic settings
Trigger a PWM from analog current feedback using the onboard comparators
Setup slope compensation for peak current control
