Vibro-Acoustic Response of Multi-Layer Systems: Creating a Condensed Model to Reduce Mesh Size and Calculation Time
A possible way of reducing the calculation time and mesh size in vibro acoustic response is to condense the description of multi-layer plates into a single, equivalent plate representation. The plate is then modeled using frequency dependent parameters in visco-elastic models. The webinar will present several representations of this approach applied to constrained layers, multi-layer plates as well as ribbed and stiffened plates.
