Skip to main content
Emulating Engineering Expertise with AI
Crashworthiness Optimization at BMW with AI-Enhanced Surrogate
Overview
Body in white crash design problems are computationally expensive, include opposing load cases and design criteria, and require a high degree of engineering expertise. By using machine learning (ML)-driven predictive surrogate modeling, BMW is able to emulate human expertise to shorten development cycles and uncover new insights for crashworthiness optimization.
Their Challenge
To ensure passenger safety, crash engineers must orchestrate the chain of events that needs to fall into place during a crash event. This includes judgments on which crash kinematic is favorable combined with the timing of discrete events such as bolts breaking or parts coming into contact at the right time. Handling key performance indicators including energy absorption, peak force level before failure, local displacements, and weight, however, can either be too complex or result in over-constrained optimization problems, making it difficult to confidently validate crashworthiness within the fast-paced product development process.
“Machine learning-based predictive surrogate modeling holds exciting promise for augmenting our human expertise, uncovering new insights, and efficiencies while shortening development time.”
– Moritz Frenzel, BMW
Our Solution
BMW uses Altair’s integrated Machine Learning solutions within HyperWorks in order to generate optimization constraints that mimic engineering expertise. Clustering, an unsupervised machine learning algorithm, helps engineers to understand how crash kinematics affect key performance indicators (KPI’s). Favorable crash kinematics are then enforced during the optimization process through the use of a classifier that, in effect, emulates engineering decision making throughout the process.
Impact/Value
Altair’s Machine Learning solutions help BMW target specific crash kinematics during structural optimization. This is achieved by mimicking engineering expertise through inclusion of ML constraints, that would be infeasible or at the very least impractical to generate manually, during optimization. This simplifies the formulation of the optimization problem and reduces the number of design iterations required to develop complex automotive crash structures.
Conclusion/The Future
This ML-powered workflow augments and extends BMW’s existing engineering expertise, allowing them to more efficiently allocate computing and human resources to high-value simulation, analysis, and validation efforts. In the future, BMW plans to explore further applications of Altair ML technologies across their design processes.
