Skip to main content
< Back to Search Results
Design of High-Performance PMSM Motor Drives with PSIM
In this webinar, we demonstrate the design and simulation of a 3-phase permanent magnet synchronous motor (PMSM) drive with PSIM. We cover PMSMs with Interior magnets (IPM) as well as surface magnets (SPM/BLDC).
PSIM features a generous machine model library for PMSMs including:
- Linear magnetics
- Non-linear magnetics
- Spatial harmonics
- HF frequency input impedance
- FEA link with JMAG models
The main control technique we use in the webinar is Field Oriented Control (FOC) and our new and improved Motor Control Design Suite enables us to quickly generate stable digital PI controllers for Id & Iq. But not only that, speed and torque controllers are also part of the presentation.
Finally, we introduce and discuss important control algorithms for maximizing the torque speed operating envelope:
- Max-Torque-per-Ampere control (MTPA): During low-speed operation of an IPM, the maximum torque available is not when Id = 0
- Field Weakening:  As the shafts speed increases the back emf of the machine increases, this combined with the voltage drop across the input impedance limits the maximum possible shaft speed at various torque levels unless the magnetic field of the permanent magnets is weakened, by changing the value of Id
- Max-Torque-per-Volt control (MTPV): As the shaft speed and torque requirements increase, Id can be further adjusted to ensure maximum torque is achieved at high speeds. Greatly increasing available power at high rpm than with just field weakening
Often our users ask us what realistic machine parameters would be if they were looking for a motor with basic torque, and speed requirements. To help answer this sort of question we now support the import of machine model parameters from the FEA tools JMAG and the free online tool JMAG express online. These motor parameters can quickly be imported into our design suite producing close-loop motor drive simulations.
We also introduce our improved capabilities for the analysis of the DC bus, including the introduction of non-ideal switches, common-mode capacitances, long cable models, and parasitic bus inductance for EMI pre-compliance simulation.
The webinar is co-hosted by PSIM specialist Albert Dunford and Mark Qin, who has many years of industrial motor drive design experience.
Please complete the form below to view this content.
