Altair Embed®
Visual Environment for Embedded System Development
Altair Embed is a powerful tool for nonlinear simulation and model-based firmware development. With Altair Embed, you design, analyze, and simulate using block diagrams and state charts. You can then automatically generate compact and optimized firmware to run on an extensive selection of microcontrollers.
Offering deep support for the most popular on-chip peripherals and libraries for electric motor control, digital power design, and image and video processing, Altair Embed lowers development costs by removing the need for manual coding which reduces errors and speeds the edit debug cycle with easy to use Hardware-in-the-Loop (HIL) capability.
Why Altair Embed?
Prebuilt e-Drive Diagrams
Field-oriented Control (FOC) motor drive diagrams let you quickly spin your motor PMSM, ACI or Synchronous Reluctance motor on your inverter.
Highly Efficient Code
The auto-generated code runs rapidly and produces high-quality results with no need to hand-code in order to speed up the execution of your code.
Test and Verify Embedded Systems
Simulate controller and plant to easily tune your controller off-line, then use integrated Hardware-in-the-Loop (HIL) to debug and tune your controller on the embedded target.
NOW AVAILABLE
Get started with the Altair Embed Personal Edition
Contains all you need for rapid firmware generation for STM32 and TI F28x including GPIO, ADC, PWM, CAN, UART, I2C, SPI. Base your project on included example suites for eMotor drives, digital power, and more.
Download Now
Key Features
Tailored for Embedded System Development
Generate efficient and compact ANSI C code for dynamic systems involving scaled, fixed-point operations. Tune parameters and monitor real-time data.
Block Diagrams and State Diagrams
Simulate dynamic systems including continuous or discrete-time behaviors as well as event-based behaviors.
Diagram-to-Code
No manual coding required. Automatically convert your block diagrams and state charts to microcontroller unit (MCU) hardware-ready code.
Support for Popular Target MCU Hardware
Includes support for a broad range of microcontrollers and processors suited for most industrial and academic applications.
Interactive HIL Testing
Run a plant model in Altair Embed on the host computer while controlling algorithm runs in real-time on the target MCU, communicating via a HotLink.
Add-ons for Digital Power and Electric Motor Drives
Simulate and generate code for power supply and digital power components and controls. Develop optimal control systems for electric drives and provide a robust algorithm for rotor angle estimation.
Key Capabilities
Rapid Diagram-to-Code
Connecting to Controller Hardware (Arduino, etc.)
Construct State Diagrams
Drone DC Motor Control HIL
PMSM Sensorless Field Oriented Control HIL
