Get Started with PE Expert 4 - Easy Implementation of a Modular Multi-Level Converter (MMC)
b3ea5ace-36c2-4230-9c5e-b0d3fca92f99.png?sfvrsn=5c99beca_1)
This seamless workflow between offline simulation and real-time simulation with working control code is unmatched in simulation speed, and ease of use.
In this webinar, we implement some simple PSIM simulations and generate code to implement on the PE-Expert4 system.
The real strength of the PE-Expert4 will show how easily it can implement a modular multi-level converter. A 3-phase MMC is being simulated with PSIM & DSIM, the power stage is exported to a Typhoon HIL 604, while the control code is exported to the PE-Expert4. The power stage is being controlled in real-time by the PE-Expert4.
Programming the platform is as simple as a click of a button, using PSIM's embedded code generation. The FPGAs are pre-programmed and their functionality is abstracted behind easy-to-use C functions which can be generated from PSIM.
