Skip to main content
Altair SimLab for Meshing
Series of videos aimed to get you started using SimLab for meshing.
Featured Resources
SimLab QuickMesh – Gear
Learn how to import a CAD geometry, mesh it with solid elements and then export it to a solver deck. Throughout the video you learn how to define the global mesh size for shell and tetra elements.
Quick Start
SimLab Meshing with Process Automation – Piston
Perform a mesh automation running a javascript or pythonscript from the process automation menu.
Quick Start
SimLab Mesh Controls – Gear
Learn how to select and isolate identify regions based on their geometry features. Tetmesh a solid body after applying mesh controls. Export all mesh controls as color based template.
Quick Start
SimLab Quick Imprinted Mesh for Parasolid Assemblies
This video shows, how to create a shell and solid mesh is generated on a Parasolid file. You also learn, how to transfer existing groups onto the mesh.
Quick Start
SimLab Volume Meshing with Layers – Housing
Request locally a given amount of tet layers through thin walls. Create a volume mesh with Tet10 from an existing, enclosed Tri6 mesh. Auto cleanup a volume mesh based on different quality criteria.
Quick Start
SimLab Hex Meshing using Extrude Functions – Y bracket
Mesh a geometry with hex elements. Generate an axi-symmetric mesh around cylinders and adjust the number of layers. Adjust the alignment of common faces and merge bodies with coincident faces.
Quick Start
SimLab Meshing with Body Break – Engine Assembly
Generate CAD features from a mesh. Cut and separate a section of a body using region mesh control. Learn how to use logo removal and mesh a valve seat. Finally create a circular gasket imprint in a body.
Quick Start
SimLab Automated Results
Improve CAE accuracy with automated results convergence
Quick Start
View More Resources
