Skip to main content
< Back to Search Results
SimLab Tutorials - Topology Optimization with Solutions - Bracket
Create a linear static solution, define loads and boundary conditions then compute; define a topology optimization, design space, constraints, response and objective; export the optimized shape as .stl; import the .stl file and perform a mesh cleanup; transfer properties and LBCs to the optimized geometry and apply TIE contact; re-analyze the model then review the results
Please complete the form below to view this content.
